Mac laptop won’t connect to router.
- My Router
- Mac laptop won’t connect to router.
12-05-2018 4:21 PM
Re: Mac laptop won’t connect to router.
12-05-2018 5:42 PM
Are you connecting via a cable or wifi? If wifi try turning off temporarily, wifi security.
Can your mac then connect?
If so, problem is with your username or password. P/word is on bottom of router, unless you've changed it.
Username is what you determined when you signed up with P Net.
12-05-2018 9:30 PM
Which router have you got?
What lights are showing on the router?
Assuming that you are using wireless are you using the wireless password to connect to your Mac, not your account password?
13-05-2018 1:50 PM
Does anything else work OK on the broadband (tablet, phone etc.) ?
What does the Mac WiFi icon (usually at top right) say when you clock on it ?
Does it say AirPort On (greyed out) ?
Any WiFi networks listed ?
13-05-2018 4:11 PM
13-05-2018 5:06 PM
Are there any special charscters in your password? It might be worth going into the router advanced settings and trying something different.
- My Router
