Loud hissing noise from Router
- My Router
- Loud hissing noise from Router
06-04-2018 5:32 PM
Our router has developed a loud hissing/buzzing noise. Are Plusnet able to replace it?
Thanks,
Tom
Message 1 of 2
(358 Views)
1 REPLY 1
Re: Loud hissing noise from Router
06-04-2018 6:38 PM
Hi Tom.
That doesn't sound good. Do you use the 5GHz wireless frequency? As that can sometimes cause buzzing.
With regards to a new router, I've provided you with some info over here.
I hope this helps.
Message 2 of 2
(343 Views)
- My Router
