Lost router admin password (plastic tab)
- My Router
- Lost router admin password (plastic tab)
01-12-2018 4:49 PM
I've lost the little bit of plastic with the admin and wireless passwords.
If I do a factory reset will this allow me to setup a new admin password or just reset it to the current one which I don't know? I've also see posts where the serial number might work as the password, I'll probably give that a try if the response here is slow.
Re: Lost router admin password (plastic tab)
01-12-2018 6:10 PM
A factory reset will not help, it will reset to that on your missing label. The serial number route only applies to old Technicolor routers. Which router do you have?
01-12-2018 7:52 PM
Thanks for the reply.
I got lucky. In addition to putting the default password on the plastic tab which I lost, it's ALSO written under the router next to the serial number I was hoping might work as a password, so I found it during my search
- My Router
