Losing wifi to Google smart devices
- My Router
- Losing wifi to Google smart devices
22-11-2020 8:04 PM
I usually have 5 google smart devices connected via wifi to my plusnet one hub. There's also other devises such as my phone etc. However, at least once a day some of the google devices lose connection. This only seems to happen to the 3rd party non-google branded devices. To get them connected again I have to reset the router. Any ideas as it's very annoying?
Labels:
Message 1 of 2
(241 Views)
1 REPLY 1
Re: Losing wifi to Google smart devices
06-12-2020 8:09 PM
You could be subject to the problem being discussed here.
I've just pushed an update to your router that might help.
You'll need to switch the router off/back on at your side to apply it.
Hope it helps.
Message 2 of 2
(158 Views)
- My Router
