Loosing Wi-Fi Connection Samsung Galaxy Tab S3
easymoney999
My tablet has started to loose connection on Wi-Fi.
I have reset the the wi-fi 3 times this morning already, Twice using the WPS and once entering the code.
When watching you tube you can get halfway thro a 30min video fine then bang wifi lost, when you look at the wifi networks available mine is saying "Authentication error occurred"
So to find where the problem was I connected my friends Huawei M5 and the same problem occurred.
Don't understand why these problem are not happening on my other wifi products thou.
Any advice would be great help................................
3 REPLIES 3
LifeonMars
Seasoned Pro
Fixes: 12
Re: Loosing Wi-Fi Connection Samsung Galaxy Tab S3
Separate the 5 GHz and 2.4 GHz in your router  is a start.
easymoney999
Sorry forgot to add in my post above,
I have std internet not fibre and use the following router,
Technicolor 582n - ADSL2+ / ADSL2 / ADSL
MasterOfReality
Seasoned Champion
Fixes: 57
Hi @easymoney999
What WiFi channel is your router currently broadcasting over?
Can you take a look here and follow the steps regarding changing channel then let us know how it goes? #
Thanks,
MoR
 MoR
