Loosing Wi-Fi Connection Samsung Galaxy Tab S3
- My Router
- Re: Loosing Wi-Fi Connection Samsung Galaxy Tab S3
26-05-2019 10:26 AM
My tablet has started to loose connection on Wi-Fi.
I have reset the the wi-fi 3 times this morning already, Twice using the WPS and once entering the code.
When watching you tube you can get halfway thro a 30min video fine then bang wifi lost, when you look at the wifi networks available mine is saying "Authentication error occurred"
So to find where the problem was I connected my friends Huawei M5 and the same problem occurred.
Don't understand why these problem are not happening on my other wifi products thou.
Any advice would be great help................................
26-05-2019 11:55 AM
Separate the 5 GHz and 2.4 GHz in your router is a start.
26-05-2019 12:02 PM
Sorry forgot to add in my post above,
I have std internet not fibre and use the following router,
Technicolor 582n - ADSL2+ / ADSL2 / ADSL
26-05-2019 9:15 PM
What WiFi channel is your router currently broadcasting over?
Can you take a look here and follow the steps regarding changing channel then let us know how it goes? #
Thanks,
MoR
- My Router
