Looking for a 3rd party modem/router that works
loiswakeman
Tearing my hair out here. After about 2 months of trouble-free operation after the last engineer visit to fix a line fault (one of a very long string!), our TP-LINK Archer VR400 dual-band router has suddenly started playing up with random periods of being unable to resolve hostnames. I tried changing the DNS to Google's but that's no better.
The original cheap 2704N router works fine, but is hopelessly basic and I really need to change it for something better so I can set up my home network. However, both the above TP-LINK router and the older one it replaces don't work reliably, and the engineer said we might have problems with the make for reasons I annoyingly didn't write down at the time.
So, if anyone can recommend a make of router that they know works for Plusnet copper, I would be very grateful. Or even some arcane settings for the Archer to get round the problem!
5 REPLIES 5
Fixes: 1,483
Re: Looking for a 3rd party router that works
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Gel
Aspiring Champion
Fixes: 29
OpenReach ones can be configured to PN settings, and have better wifi reach too than that supplied by PN. Loads on E Bay.
loiswakeman
Thanks Gel - will have a look.
Fixes: 417
@loiswakeman
 The BT Smarthub 6 is cheap, available on  Ebay and better than Plusnet's hubs.
These work on both standard ADSL and fibre. Setting instructions are here. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
loiswakeman
Great - that's really helpful - many thanks. Will give one a try and keep my fingers crossed 🙂
