Login Details For Router? Technicolor DGA0122
Hartland
I'm trying to login to my router profile. I'm unsure what the username and password is.
Please can someone advise me with this. I haven't changed any of these details to my knowledge.
Any advice on this would be appreciated. Thank you
3 REPLIES 3
Fixes: 582
Re: Login Details For Router? Technicolor DGA0122
Im guessing this isnt a Plusnet supplied router since I dont recall them supplying that model.
According to this https://support.aa.net.uk/Technicolor_DGA0122 there should be a sticker on the back with the default credentials
Hartland
Thank you for getting back to me.
There is a sticker on the back and apparently the password is the details under "Access Key". I have tried entering this and it still won't let me login.
Any thoughts?
Fixes: 582
In that case it would seem that it has been changed from the default.
A factory reset SHOULD revert it to that shown on the sticker BUT beware a reset will lose all your configuration.
