Limiting Incoming Traffic
I am using the Hub One router, I have port forwarding setup.
Is there a way of setting up the firewall/port forwarding, So a certain external IP can communicate with a particular internal machine ?
Is it possible to limit where the incoming traffic is from ?
Any advice would be appreciated.
Thanks.
