Latest Firmware foe 2704n Router Request
- My Router
- Latest Firmware foe 2704n Router Request
22-10-2020 6:51 AM
Hi could i get the latest firmware for the PN 2704n router Im currently on 7.275.11_F2704N_Plusnet...I belive that 7.275.12 is avilable. Thanks
Re: Latest Firmware foe 2704n Router Request
22-10-2020 6:59 AM
7.275.11 is the current production firmware. Why are you requesting it is updated?
22-10-2020 7:22 AM - edited 22-10-2020 7:29 AM
I getting alot of buffering currently and been unable to sort it since joining Plusnet and hoping it may work
my router just disconnected i think there maybe a issue from the bt exchange as it was a net socket install and had issues ever since BT Openreach done install.
Im currently having buffering issues every night from 7pm onwards
22-10-2020 11:27 AM
22-10-2020 11:09 PM
@TheGamer147 - it's worth you opening a fault ticket. I'm not sure a firmware update is going to help here 😕 - http://faults.plus.net
10-12-2020 7:09 AM
19-12-2020 7:28 PM
@TheGamer147 - there isn't an update available that will assist with the issues you're reporting I'm afraid.
19-12-2020 9:37 PM
29-12-2020 6:03 PM
@Deividas1981 this thread is about the 2704n/Hub Zero router. It doesn't have a 5GHz radio? Could you be affected by this? If so, probably better to post over there.
- My Router
