Laptop disconnects from router
- My Router
- Re: Laptop disconnects from router
07-09-2019 5:50 PM
Does anyone have any idea why my laptop sometimes disconnects from the router? Its just my laptop, everything else (my kids laptops, phones, PS4) all work. I remember I had this problem a few years ago and I think I was advised to delete something (in hardware I think) then install it again but I cant think what it was. The only way I have found of 'solving' the problem is to switch the router off and on but id prefer not to do that indefinitely and rather find the cause if possible. TIA
07-09-2019 10:22 PM
Moderators Note
This topic has been moved from Fibre to My Router
07-09-2019 10:23 PM
08-09-2019 5:42 PM
08-09-2019 6:16 PM
Hi, thanks for replying. Yes it's wireless and Windows 10 (Lenovo laptop)
09-09-2019 12:00 PM
10-09-2019 12:53 AM
Hi there, thanks for replying. This link you sent me is familiar, I remember device manager and network adapters being mentioned.My laptop is ideapad 320s 14IKB. I havent done anything yet, so will I just go ahead (later on today) and follow the instructions? SHould I do a backup first? thanks
10-09-2019 1:57 PM
Hi @Bright8,
I'm afraid that's starting leave the remit of what we can advise on as staff, but I'd say if you follow the instructions included on the relevant guide then you should be fine. If there's further issues following this it'd be best to contact your manufacturer for further support.
- My Router
