Keeps dropping out?
Fixes: 388
Re: Keeps dropping out?
OK. In that case, can you navigate to the page in the screenshot below, click the 'Export' button, and attach the result to a post, please?
Surfer
Thanks.  Attached is the event log.
Fixes: 388
From that log, it is evident that you are losing DSL connection at an unacceptable frequency. Report the fault again,
@Tina11192 - can you please revisit this subject?
Surfer
Thanks for the update as it is getting very frustrating.  Don't need this sort of stress at our age.  Just to check I also disconnected the VOIP from the router just in case, but problem persists.
Fixes: 388
Reconnect the phone - that is not the issue. As said, please report a fault.
Fixes: 585
@Surfer have you tried connecting the router to the test socket (using a filter) by removing the master socket cover ?
Surfer
Thanks.  I prefer not to interfere with any electronics especially when it does not belong  to me.
Fixes: 585
Unclipping the front of the OPenreach master socket and using the test socket is a standard troubleshooting test that's expected of a customer. It eliminates the possibility of the fault being the customers responsibility.
The later Mk5c faceplate also have a tendancy for a poor connection as the contacts are not gold plated any more.
Surfer
I appreciate your input, but my thoughts is that the box is the property of Openreach and not a customer access box and also not my responsibility to do checks by opening it up.
Fixes: 388
So what are you going to do to resolve this issue?
outcast
Aspiring Champion
Fixes: 19
The property of Openreach ENDS at the TEST SOCKET,
The removable faceplate and any internal wiring is your responsibility.
Watch this video to see how simple it is - YouTube : How to connect to the master test socket
It will be less daunting than you think  😀
Surfer
Okay what am I supposed to do once the faceplate has been removed?  Totally clueless!
Fixes: 388
Plug the cable you removed from the master socket before removing the faceplate into the test socket?
Fixes: 585
Unless you have a dual socket faceplate , in which case you will need to plug a DSL filter into the test socket and then the router cable into the filter
Surfer
Before I even got to the socket, the router start flashing orange again and internet lost!  However on going to the 5C socket, there is no way I can get the front cover off.  The right side of the socket is right up against the frame of the window so cannot press the clip to release the front.
