Showing results forย
Keep loosing broadband ๐ฟ
- My Router
- Keep loosing broadband ๐ฟ
โ24-04-2019 7:23 PM
<p>I am having to reset my router more and more often as I keep loosing my broadband. Happen 3 times this evening and becoming a pita! </p>
<p> </p>
<p>Log shows "Event code(s): '1 BOOT,4 VALUE CHANGE" </p>
<p> </p>
Message 1 of 2
(383 Views)
1 REPLY 1
Re: Keep loosing broadband ๐ฟ
โ24-04-2019 9:14 PM
Hello @masson125,
Please accept my apologies for the issue with your broadband service.
After testing the line, we can see that your service has dropped 3 times within 24 hours but the speed is between the estimates for the line.
As you are powering off the router when the connection drops, do you know if the connection reestablishes when given the time to reconnect? Due to the event log, please connect your router to the test socket and if the persists raise a fault. Once complete, let us know on here so we can progress the issue.
Thank you.
Message 2 of 2
(369 Views)
