Is there a better router to replace the One hub on fibre broadband?
- My Router
- Is there a better router to replace the One hub on...
18-07-2020 1:15 PM - edited 18-07-2020 1:25 PM
My Plusnet One hub seems to work OK, but I feel it could be better and maybe it just needs an update on software version 4.7.5.1.83.8.263 | Last updated 27/02/19?
On Wi-Fi, Alexa is erratic and drops off as does the 5g to a phone and a Mac and Netflix, Amazon and YouTube tends to toggle from 4k to 720HD or give the odd spinning circle of wait.
Looking at this forum https://www.cnet.com/forums/discussions/when-should-you-replace-your-wi-fi-router/ it seems to suggest updating and/upgrading is a good idea.
Re: Is there a better router to replace the One hub on fibre broadband?
18-07-2020 1:17 PM
This topic has been moved from Fibre Broadband to My Router.
Customer and Forum Moderator. Windows 10 Firefox 100.0.2 (64-bit (64-bit)
21-07-2020 11:11 AM
Hi there @Leapy You'd be best posting on this forum post to get your Hub One firmware updated.
- My Router
