Is the Plusnet Hub One VDSL or VDSL2 ?
- My Router
- Is the Plusnet Hub One VDSL or VDSL2 ?
18-06-2018 11:35 AM
As above please...
I'm looking into replacing the Hub One with a self-configured OpenWRT router for control over privacy, but want to find a replacement router of the right protocol / technology to make the most out of my connection.
Thanks, Scott.
Re: Is the Plusnet Hub One VDSL or VDSL2 ?
18-06-2018 11:46 AM
You might find this post on the kitz forum useful if you are looking to find a replacement router for the HubOne:
https://forum.kitz.co.uk/index.php/topic,14436.0.html
18-06-2018 12:35 PM
You are asking the wrong question, which should be: is BT FTTC VDSL or VDSL2?
I believe that the answer is VDSL2 but you can do your own Google search.
18-06-2018 12:53 PM
Hi Baldrick1; lack of a difinitive answer found via searching the internet led me to asking the question on the forum. Ideally I just wanted to find a datasheet / specification of it's capabilities.
I was wondering if the hardware of the One Hub router is capable of VDSL or VDSL2 speeds (or both), as when I replace it I will get one that uses the same technology, so I can be confident that it'll work with my plusnet subscription.
No point in going for VDSL2 to find it won't work with plusnet's VDSL service, or vice-versa..
The BT street cabinet does have fibre, however, I'm unsure as to the standard of their (BT's) fibre network.
Jaread83, Thanks for the link to that list of alternative routers, I'll have a read and see which are supported by OpenWRT and choose a good model to re-flash with the custom firmware.
18-06-2018 3:57 PM
I confess to knowing nothing about openWRT but am now totally confused. As all iopenWRT is is different firmware for the router then surely any router from the @jaread83 list will be compatible with the BT infrastructure? All it needs to be is capable of supporting openWRT.
- My Router
