Is router packing in?
- My Router
- Is router packing in?
07-04-2020 5:54 PM
For a couple of weeks I've been having issues with wifi signal dropping , it seemed like the issue some are having with the 5G only with me it was the 2.4G .
Last week I split my 5G and 2.4G and using wifi analyzer I did see the 2.4 signal dropping every few seconds , but the 5G was fine , so ended up switching some of my devices to that, then it seemed OK for a few days, until I noticed the 5G doing it also.
Rebooted the router yesterday and all seemed fine until later today , downloads dropped to only 0.05 Mbps , yet upload speed was unaffected ,unusually also the wired connection , wifi analyzer showed wifi signal was OK?
Anyway I've just rebooted again and all is OK for the moment , I'm just wondering if my router is about to pack in altogether.
Re: Is router packing in?
11-04-2020 10:40 PM
Update: Since the last reboot it's been OK (4 days) that I've noticed at least, until today , began with the same issues , 2.4 dropping every few seconds , 5G was OK , currently though I cannot connect to 5G now , although wifi analyzer shows signal OK, but 2.4 is back working?
