Is my i phone using 2.4 or 5 ghz ?
zerommatt
I'm an amateur so plain language please. I have a home security camera system and part of the set up requires pairing a camera with my i phone 4s to operate and communicate with the camera.
It won't pair and the first check i have to do is to make sure that the phone is using 2.4 ghz not 5. I have no idea how to do this and despite looking at various other web sites still can't figure it out. Have been into the router and can't even see my i phone connected to the wi fi, let alone what frequency it's using. Any help would be greatly appreciated.
5 REPLIES 5
Kdog
Fixes: 9
Re: Is my i phone using 2.4 or 5 ghz ?
If it's not showing in the home network in the router that's a little odd-unless it's named something else in there. It would also be helpful to know which router you're using.
All that said mind I don't think the iPhone 4s can use 5Ghz Wi-Fi anyway so it must be on the 2.4 band.
bill888
Champion
Fixes: 36
Separate the 2.4 and 5 GHz wifi networks as described in this link:
https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/td-p/1351950
Then you can choose whether your iphone connects to 2.4 or 5 GHz wifi.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
hangar18
I would check that your phone wifi is turned on and is actually connected to your router.  Ensure it is not using the mobile data network (3G/4G etc).
As @Kdog said, the iphone 4s cannot use the 5Ghz Band so that is not the issue.
zerommatt
Hi, thanks for the help, the router is a sagemcom 2704N.
If the phone only uses 2.4 then that answers my query, thanks again !
Kdog
Fixes: 9
That confirms it from both sides then-the sagemcom is 2.4 only too it regardless of the phone.
