Is my i phone using 2.4 or 5 ghz ?
- My Router
- Re: Is my i phone using 2.4 or 5 ghz ?
21-07-2018 12:02 AM
I'm an amateur so plain language please. I have a home security camera system and part of the set up requires pairing a camera with my i phone 4s to operate and communicate with the camera.
It won't pair and the first check i have to do is to make sure that the phone is using 2.4 ghz not 5. I have no idea how to do this and despite looking at various other web sites still can't figure it out. Have been into the router and can't even see my i phone connected to the wi fi, let alone what frequency it's using. Any help would be greatly appreciated.
21-07-2018 8:07 AM
All that said mind I don't think the iPhone 4s can use 5Ghz Wi-Fi anyway so it must be on the 2.4 band.
21-07-2018 10:23 AM
Separate the 2.4 and 5 GHz wifi networks as described in this link:
https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/td-p/1351950
Then you can choose whether your iphone connects to 2.4 or 5 GHz wifi.
21-07-2018 11:44 AM
I would check that your phone wifi is turned on and is actually connected to your router. Ensure it is not using the mobile data network (3G/4G etc).
As @Kdog said, the iphone 4s cannot use the 5Ghz Band so that is not the issue.
21-07-2018 10:11 PM
Hi, thanks for the help, the router is a sagemcom 2704N.
If the phone only uses 2.4 then that answers my query, thanks again !
21-07-2018 10:49 PM
- My Router
