Is my TG582N firmware u.t.d?
Luzern
Fixes: 9
Quickie! Is 10.2.2.B the latest? That's what I have, but I've only recently brought the router back in to use, when my other one played up.
4 REPLIES 4
Aspiring Legend
Fixes: 195
Re: Is my TG582N firmware u.t.d?
Quick answer @Luzern - that is the latest (and last, I would guess), firmware.
Luzern
Fixes: 9
Thank you!
typonaut
I can't see that is likely, given that mine has 10.2.5.2.FO.
ejs
Aspiring Hero
Fixes: 25
There are different firmware versions intended for ADSL and for FTTC use. 10.2.2.B is the last firmware for ADSL use. 10.2.5.2.FO is the last firmware for FTTC. You can re-configure the 10.2.5.2 FTTC firmware and use it for ADSL, although the FO version does have a bug where it fails to re-enable the WAN Ethernet port for LAN use when switching from FTTC mode to ADSL mode (which can be solved using telnet commands).
