Is it worth upgrading Router
- My Router
- Is it worth upgrading Router
28-12-2016 4:31 PM
Hi All. I have a Plusnet installation at a rental property, ADSL getting about 8-9 Mbps on a country telephone line which isn't too bad! I'm using the Thompson 585 router which seems pretty reliable. I have the option of upgrading to the Plusnet Hub One (a friend left Plusnet and gave me his router).
Being a holiday let rental installation, reliability is very important.
Would your advice be to install the new Hub one, or leave as is?
Thanks for any assistance
Re: Is it worth upgrading Router
28-12-2016 6:30 PM - edited 28-12-2016 6:40 PM
I have the Plusnet Hub one in my house and it is reliable it's up to you really. Been the newer model it's has better hardware inside it but it's nothing really special it's up to you really.
James
EDIT: only main advantage is the 2.4GHZ and 5GHZ bands for wifi with the 5GHZ been more reliable again been in the countryside interference is likely to slim.
28-12-2016 7:52 PM
In my own opinion, if your current Thomson router is working reliably with no issues I'd personally continue to use it.
Having said that, the Hub One does have improved wireless spec.
If you do decide to use the new router you'll need to go through the router settings and manually connect with your broadband username and password.
The broadband username (Login Name) you can find here: https://www.plus.net/my.html?s=0&action=refresh_browser
28-12-2016 8:45 PM
If it ain't broke.....!
28-12-2016 8:50 PM
...don't fix it.
If the OP is undecided, if it was me I'd probably setup the Hub One and see how it goes. The option is always there to go back if they keep ahold of the Thomson router.
29-12-2016 10:32 AM - edited 29-12-2016 10:34 AM
Many thanks for your input. The router is in quite a large property so there are areas of poor wifi signal. I did have an extender till one of our holiday makers nicked it! So may give the Hub One a go to see if it improves range.
Thanks again
29-12-2016 11:02 AM
If you're going to try the Hub one it would be a good idea to make sure that it has been disassociated with your friends account. If not then, when factory reset, it will automatically configure with your friends login details. I'm sure @Anoush or one of the other PN help team members will be able to check. They will probably ask you to PM them the serial number of the Hub one.
29-12-2016 1:20 PM
@PeteNW You will never know until you try, but if you ever come across a BT hub 3 the WIFI range is pretty good.
29-12-2016 5:56 PM
Yeah, if you private message me with the serial number from the label on the bottom of the router @PeteNW I'll ensure it's not linked to an account.
The serial number should begin with +081441+
29-12-2016 10:16 PM
Many thanks Anoush. Will take you up on that.
- My Router
