Is it my wifi router that has broken?
- My Router
- Is it my wifi router that has broken?
03-10-2018 8:24 PM
Re: Is it my wifi router that has broken?
03-10-2018 8:28 PM
03-10-2018 8:53 PM
With the old router it would need to be manually configured with your plus net account username and password. What model of router is it?
its not necessarily a router fault . It might be a line fault.
But first of all you'd be best off doing a factory reset of your old router . Ther will be a reset button on the router and you'll need a pin to press it in while the router is turned on.
if that doesn't work then report a fault to Plus Net support
Hope this helps
04-10-2018 8:00 AM
04-10-2018 1:43 PM - edited 04-10-2018 1:44 PM
04-10-2018 2:16 PM
Moderator's note:
Topic moved from Broadband to My Router
04-10-2018 6:51 PM
Does it sound like the newer WiFi router is the problem then?
04-10-2018 7:01 PM
There is a user manual for the Voyager here
Relevent info:
6 Start your Internet browser and type in the address 192.168.1.1 7 The Configuration Manager screen should open.
8 On the Configuration Manager screen, enter your Broadband User Name and Password. Your Username will take the following form:
PlusNet: (www.plus.net) :username@plusdsl.net Force9 (www.force9.net) :username@f9.co.uk Free-Online (www.free-online.net) : username@freeonline.net
9 Click Connect. 10
04-10-2018 8:05 PM
Hello @rachelm,
Thanks for getting back to us. Please follow the steps outlined by Mustrum, and get back to us if you have no success.
We would be happy to send a new router.
04-10-2018 8:23 PM
05-10-2018 12:18 PM
Hit @rachelm
I have processed this for you, and a new router has been sent out. You should receive this within 3-5 working days.
- My Router
