Is Plusnet better than Talktalk @38mbs
- My Router
- Is Plusnet better than Talktalk @38mbs
21-12-2019 3:20 PM - edited 21-12-2019 3:22 PM
Hello all
I have been with Talktalk (38mbs) for couple years. They are the only ISP I have tried fibre on.
I am shopping around if anything better for similar cost.
So has anyone moved from Talktalk to Plusnet and able to share their experiences please
Did the connection speed change? Did the Wi-Fi range change?
Another point i notice people are using BT smart hub 6. Is that modem a big upgrade over the Plusnet default hardware.
Re: Is Plusnet better than Talktalk @38mbs
21-12-2019 6:26 PM
Both TT and Plusnet use the BT infrastructure so I would not expect the speed to be any different.
BT Retail supply a Smarthub 6 or Smarthub 2. Plusnet, who are BT's budget provider, supply a Hub One, which is an old BT Home Hub 5A in a different case and slightly tweeked firmware. Enough said?
21-12-2019 6:26 PM
21-12-2019 7:39 PM
I moved from plusnet to Talktalk (2 years ago) and back to PN (1 year ago), IMO there's no difference in performance but support is better here. Just following the deals
If you have the talktalk HG635 router that can be used on PN and gives good performance.
22-12-2019 7:42 AM - edited 22-12-2019 7:44 AM
Thanks @Baldrick1, @npr & @bmc for your feedback
Positive feedback. In that case I shall move over to Plusnet shortly as they seem to have better deal of £60 cashback.
So is the BT Hub 6 upgrade people doing better than the default hardware of re-badge Hub 5.
@npr That HG635 modem is very old, Talktalk recently released a new modem and seems to be decent.
22-12-2019 10:35 AM
Have you checked out the cashback sites? 😉 £££
The hg635 is still worth using IMO, it was replaced by the hg633 which is locked to TT.
22-12-2019 3:23 PM
In my experience the Smarthub 6 does not suffer the wireless problems reported by Hub One users. Neither does it exhibit the noise problems reported by some. See here for a comparison of wireless performance https://www.businessdirect.bt.com/content/uni2/documentation/c6nx/bt_smart_hub_test_report.pdf
22-12-2019 8:33 PM
When i joined Talktalk they issued HG633. It was a terrible router with contact drop outs.
It was so bad i bought a used aftermarket TP-Link VR900 and it was day and night until it died 6 months ago.
Later Talktalk released D-link 3782 which was maybe same rubbish spec as HG633.
The lastest router Sagem 5364 seems to have improved a bit but no where near the VR900 i used before.
Noticed the £70 cashback if i jump to Plusnet
22-12-2019 8:35 PM
Thanks for the feedback.
So when i move to Plusnet its ideal to buy a used BT smart hub 6 from Ebay then.
Seen they sell around £25.
22-12-2019 10:31 PM
It’s your choice whether to get one. They go for less than £25. The business versions have more accessible options such as you can select which DNS server to use. There are FFTP versions around. These have a red WAN sticker fixed to one of the yellow LAN sockets. These work but are best avoided as you lose the use of one LAN socket. Setting instructions are here. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
- My Router
