Interrogate a router
lbproperties
I recently contacted Plusnet re very slow internet and pages simply not loading. It transpires we have been using up to 15gb a day uploads which we’ve narrowed down to our lodger being on video calls a lot!
Is there a way to interrogate the router to highlight usage for each device over a period. Hopefully that makes sense.
Thank you in anticipation
Plusnet hub one
8 REPLIES 8
Fixes: 480
Re: Interrogate a router
@lbproperties  Welcome to the Plusnet Community Fora.
Yes there is, you need to log into the hub and select My Devices, this will show you a list of devices and the stats you require. If you want more info please advise which nub you are using.
@Baldrick1
The OP stats he has a Hub One, which does not detail a device usage data as you described
EDIT: To view the internet connection overall data usage from the Home page navigate to
Troubleshooting >Helpdesk "Line 11 Data sent/received:"
lbproperties
Dan thank you, found that but I think my only option would be to reset the figures each day. Tried resetting and disconnecting the router but the values remain. Out of interest does a hub 2 have the option described by the moderator?
It does, looks like
HTH
Have you checked if you are able to upgrade to a Full Fibre package, with plusnet or a alternative provider to Openreach?
https://checker.ofcom.org.uk/en-gb/broadband-coverage should detail who is available to you
https://www.broadbandchecker.btwholesale.com/#/ADSL should detail Openreach offerings. (Use the address option if you do not have your landline phone number)
HTH
Fixes: 480
@lbproperties wrote:
… I think my only option would be to reset the figures each day. Tried resetting and disconnecting the router but the values remain.
I would simply record the numbers each day and do the maths.
lbproperties
Hub2 ordered, thank you
greygit1
It'd be much simpler if there were an option to reset the counters. IMO.
In the past routers supplied by PN used to have that Smiley
