Installing an ASUS DSL-AC88U drops download speed?
neryswalters
Was getting 30mb download speeds with the plusnet router however with the new Asus router speed is stuck at 9mb
7 REPLIES 7
Fixes: 1,600
Re: Installing an ASUS DSL-AC88U drops download speed?
Thanks for getting in touch @neryswalters
Do you have any Quality of Service(QoS) enabled in your ASUS router which may be limiting your download speed?
neryswalters
No QOS isn't enabled, and you can see that the connection stats show a 9mb connection
Mustrum
Fixes: 77
You have not exactly give much information to go on.
It is likely to be a configuration problem, or mybe a faulty router.
What settings do have in the WAN tab?
neryswalters
The same problem occurred on another non-plusnet router so wont be a faulty router setting, the settings are attached which were provided by the setup wizard specifically for plusnet
Mustrum
Fixes: 77
Your ANNEX mode is set to B, I believe it should be A.
But I can;t see any other issues.
Mustrum
Fixes: 77
Forget the Annex bit, seems I was wrong, but too late to edit my reply.
Fixes: 1,483
Moderators Note
This topic has been moved from  Fibre to My Router
