Improved WiFi range & VPN server
- My Router
- Improved WiFi range & VPN server
05-04-2018 7:17 PM
Still a bit stuck for recommendations for improved WiFi range router with logging and also an option to use as a VPN server. Does anyone use something similar that's an improvement over the hub one?
Thanks all!
Re: Improved WiFi range & VPN server
13-04-2018 4:50 PM
TP-Link Archer VR600 would tick both the improved WiFi Range and VPN server boxes and is based on a broadcom chipset.
https://www.tp-link.com/uk/products/details/cat-15_Archer-VR600.html
Cheapest I could find it was £55 on John Lewis web site
The manual is here if you want to look it first:
https://www.manualslib.com/manual/1265884/Tp-Link-Archer-Vr600.html?page=70#manual
15-04-2018 9:40 PM
Great,
Funnily enough i found the VR400 , however it seems the VR600 V2 is actually cheaper! So ill plump for that instead! Thanks for this. Really helpful
16-04-2018 11:18 AM
If I were looking for a new router I'd probably go for one of the Asus routers that support OpenVPN as that's much more secure than PPTP, L2TP. Also the ASUS routers get a good reception here.
I have a VR600 & the Wi-Fi is good on that. Strangely it doesn't support VPN. Possibly it's an earlier model.
16-04-2018 6:57 PM
- My Router
