If I order the basic Plusnet router for now, can I easily switch to a BT Smart Hub 6 after?
- My Router
- Re: If I order the basic Plusnet router for now, c...
28-12-2017 7:50 PM
On checkout it says using my own router? or allows me to order a plusnet router for now. (I'm ordering 17mb ADSL BB)
Can I use the plusnet router for a month and then easily switch or do I need to use the BT Smart Hub from day one?
Message 1 of 3
(760 Views)
2 REPLIES 2
Re: If I order the basic Plusnet router for now, can I easily switch to a BT Smart Hub 6 after?
28-12-2017 8:04 PM
Not a problem - you can switch whenever you like.
Message 2 of 3
(745 Views)
28-12-2017 9:53 PM
Aye that's correct @thecharleskerr
Message 3 of 3
(710 Views)
- My Router
