IPSec VPN on Technicolor TG582n
FIXED- Subscribe to RSS Feed
- My Router
- IPSec VPN on Technicolor TG582n
01-11-2016 10:08 AM
Does anyone know how to setup an IPSec VPN on a Technicolor TG582n Router? The router would need to be the VPN Endpoint.
I am unable to setup PPTP as we use Mac OSX Sierra so PPTP is no longer supported...! Connection Applist is below.
{admin}=>connection applist
Application Proto DefaultPort Trace Timeout Child Qos ALG specific config
IP6TO4 6to4 0 disabled ------ ------
PPTP tcp 1723 disabled 5' 0" ------
ESP esp 0 ------ 15' 0" ------
IKE udp 500 disabled 15' 0" ------ FLOATING
SIP udp 5060 disabled 10' 0" VoIP-RTP trace level: none
JABBER tcp 5222 disabled 2' 0" ------
CU/SeeMe udp 7648 disabled ------ ------
RAUDIO(PNA) tcp 7070 disabled ------ ------
RTSP tcp 554 disabled 2' 0" Video
ILS tcp 389 ------ 5' 0" ------
H245 tcp 0 ------ 5' 0" ------
H323 tcp 1720 disabled ------ ------
IRC tcp 6667 disabled 5' 0" ------
DHCP udp 67 disabled 1' 0" ------
GAME(UDP) udp 0 disabled 1' 0" ------
CONE(UDP) udp 3478 disabled 5' 0" ------
LOOSE(UDP) udp 0 disabled 5' 0" ------
SNMP_TRAP udp 162 enabled ------ ------
FTP tcp 21 disabled ------ None
{admin}=>
Fixed! Go to the fix.
Re: IPSec VPN on Technicolor TG582n
01-11-2016 10:46 AM - edited 01-11-2016 10:46 AM
L2TP Forwarding
UDP 500 (IKE)
UDP 4500 (IKE)
UDP 1701 (L2TP)
Protocol 50 (ESP)
I have no particular experience with the Technicolor router I'm afraid
01-11-2016 10:49 AM
Thanks for the reply, I will try adding this to the bind list and see what happens.
01-11-2016 11:18 AM
I don't think the TG582n supports VPN endpoints.
01-11-2016 12:39 PM
I agree. I think I will go down the route of setting up Mac as a VPN Server with Mac OSX Server...
- My Router
