Hub2 Firmware v0.10.00.04201 - What's Changed?
My Hub2 rebooted itself overnight after upgrading its firmware to v0.10.00.04201-PN.
I have done a search on these forums, but only found one post on this, from @dvorak confirming that it is the current version.
Does anyone on here know what has changed please?
3 REPLIES 3
Fixes: 1,495
Re: Hub2 Firmware v0.10.00.04201 - What's Changed?
Unfortunately release notes aren’t published for the updates.
However, I believe it was mentioned that one of the things it changes it totally disabling wifi including the hidden ssid
@dvorak
Thanks for the reply.
"totally disabling wifi including the hidden ssid"
I'm sure that I already had that feature from the previous firmware upgrade that I received in November 2022?
I have a BT Whole Home WiFi mesh system and don't use the Hub's WiFi signal, so made use of the feature back then.
Unless it didn't work properly last time, though my WiFi Analyse app definitely showed the previously hidden SSID as no longer there?
Fixes: 585
I dont think that part of the configuration was saved in a backup. This firmware corrects that. I believe it also corrects a problem when using bridge mode on ADSL connections.
