Hub1 USB Restrictions
Ian_S
Hi. Are there some restrictions which apply to the type of USB Flash Drive you can use with the Hub 1? I want to use a 64G stick, but the hub won't recognize it. It works fine with a 2G and 8G stick, but not the bigger one. I thought there must be a maximum size limitation, but I plugged in a 250G USB HDD, and that works perfectly!
Ian
3 REPLIES 3
Browni
Aspiring Hero
Fixes: 60
Re: Hub1 USB Restrictions
How is the USB stick formatted?
According to the hub's online help it supports FAT16, FAT32 & NTFS.
Mustrum
Fixes: 77
Yes there are restrictions on the USB port, if you do a search on BT Home Hub 5 USB you will get more information, the Hub 1 is based on the HH5.
Ian_S
Thanks for the reply. It's formatted exFAT, so maybe that's the problem (althoigh I thought the other ones I tried were exFAT also). I'll ttry re-formatting to NTFS
Ian
