Hub two Modem only
KFordnew
Hub two Modem only
So am trying to setup my Asus RT-AX88U router with the Hub two i switched the hub two to bridge mode and the light shows pink confirming modem only, when to login to the new router CP a message shows which says DCHP not functioning correctly.
I have tried setting DCHP frequency to aggressive mode and no luck, also tried disabling WIFI 6 as i belive to hub two will not support with. Any help will be greatly appreciated.
4 REPLIES 4
Fixes: 585
Re: Hub two Modem only
@KFordnew have you configured the WAN setting on the Asus RT-AX88U for PPPoE and entered your PlsuNet credentials ?
When in modem mode the Hub 2 wifi is off , so any wifi setting can be used on the Asus RT-AX88U
As @MisterW  says everything on the Hub Two is turned off it's now just a modem, you need to connect Hub Two LAN1 2 or 3 to the WAN port of your ASUS router.
KFordnew
What credentials would it need as I’m unsure which username and passwords to enter
Fixes: 1,495
your plusnet account details, that you would sign into the member centre with.
Username: <pn portal username>@plusdsl.net
Password: <pn portla password>
