Hub reset and needed log in again - hack or malfunction?
- My Router
- Hub reset and needed log in again - hack or malfun...
28-04-2021 10:17 AM
Hi all, while our problem is technically "fixed" I'm a little worried that something suspect is happened.
Last night ( approx. 12midnight) our internet dropped out ( Amber light, Red broadband B), had a quick go with resets but I was tired and needed sleep!
Woke up this morning, read through the booklet - relogged into the Hub Manager and everything is fine (so far).
I did wonder though, what caused this to happen, for the hub to reset itself and need logging in again. Was this a fault with the device or did someone try to hack us? How can I see who/what has logged in to our hub?
Cheers, V
Re: Hub reset and needed log in again - hack or malfunction?
28-04-2021 10:22 AM
@Beeferoni Welcome to the forum
It could have been anything from BT maintenance work through a surge on the mains to the hub having a random wobbly. It is very very unlikely to have been caused by a hacker. Only worry about it if it becomes regular.
28-04-2021 11:43 AM
Moderators Note
This topic has been moved from Fibre to My Router
- My Router
