Hub one wifi problem
- My Router
- Hub one wifi problem
30-11-2019 7:21 PM
I keep losing wifi to pretty much everything I have 2 galaxy a70's and 2 iPhone se and galaxy tab a and various other bits and bobs. The connection is constantly being lost primarily on the phones. I have separated 2.4 and 5GHz and the router is plugged directly into the test socket. Any suggestions as it has now got to the stage that I have given up and use 4g ...
Message 1 of 2
(413 Views)
1 REPLY 1
Re: Hub one wifi problem
01-12-2019 7:49 PM
Thanks for getting in touch @Pedders006
I'm sorry to see you're experiencing wireless problems. I've tested your line and there are no issues showing with the broadband signal going into your router and it looks like the 2.4GHz frequency is still merged with the 5GHz.
Can you carry out the steps Here making sure you rename one of the frequencies to something different?
Let us know how you get on.
Message 2 of 2
(336 Views)
