Hub one security ssid not secure
Legend
Fixes: 253
Re: Hub one security ssid not secure
@moonson I'd just ignore the warning. Apple are just covering their backs (and being an American company, are paranoid about 'security')
Once you have joined Plusnet, they will only replace a modem/router if it fails during the first year, or if you re-contract and request a new router at the time - if you want a different/better one, that is at your expense.
Out of curiosity, how are you running a FTTC connection on a TG582n router - it is an ADSL-only product?
Fixes: 392
BT VDSL Modem!. The early FTTC installs were supplied with one. There was a firmware variant of the TG582n which converted LAN port 4 into a WAN port. I think the last version of the TG582n firmware , you were able to select FTTC or ADSL on setup.
Legend
Fixes: 253
Never thought of that, @MisterW  - the setup must be a bit ancient then.
moonson
yes there is a BT box as well
{it's in an inaccessible corner 😉 and I'd got no further than looking at the router control page 192. etc
Yes it is probably what qualifies as an old intallation
I'm rarely inclined to mess with something that is working
would having a more recent box at this end make anything any better?
not looking to spend money just to have a new one, but if it would be a big step forward I should think of doing it sometime
I think the biggest barrier to great service where i am is a dodgy BT box up the road... but I may not be "up to speed" (pun intended) with the details
Legend
Fixes: 253
To be honest, @moonson  - if it is working, I would leave it alone.
I'm no expert on FTTC, but do you get the expected performance as you are currently set up?
moonson
well no, but I blame the box up the road for that 😐
i'm happy enough with my broadband, everything's working at the moment, it doesn't cost too much
this will serve as a reminder that there are issues there... and when I evebtually get round to seeing what they are i'll be back here asking the wizards about it
thanks
