Hub one security ssid not secure
caney97
After the last Apple update the WiFi connection is showing as not secure. It says to change to wpa3 but the Hub One hasn’t got this feature in the settings. Do I need to buy a different router and input the broadband login details manually?
35 REPLIES 35
Fixes: 1,483
Re: Hub one security ssid not secure
Moderators Note
This topic has been moved from Fibre to My Router
Fixes: 1,483
I don’t have WPA3 and none of my Apple devices have shown this. WPA2 is perfectly fine.
Where / what is showing this message?
caney97
If i click on the WiFi in settings to show my connection it says security weak, change to WPA3.
caney97
Fixes: 1,483
I haven’t got a hub one set up - but can you check it if supports WPA2-AES rather than TKIP?
Think it should.
caney97
Only says WPA2 only no AES or TKIP.
Fixes: 418
@caney97
I think that you will find that the Hub One uses the WPA2 personal protocol, which is considered adequate for home use. If you want something better then you will need to buy your own router.
bobpullen
Fixes: 316
Interesting. Is this iOS 14?
I was under the impression the Hub One uses AES rather than TKIP. It doesn't support WPA3 though.
caney97
Yes it is IOS14. The warning was not there in the previous version.
bobpullen
Fixes: 316
Thanks. Won't be around to look into this further until next week. In the meantime, interested to know if any other iOS 14 users are seeing this with their Hub One?
Mook
Seasoned Champion
Fixes: 9
It's not just the Hub One @bobpullen, I get the same message on my iPhone 6 (v14) about my WiFi connection to my Apple AirPort
Fixes: 1,483
It's a feature of iOS 14 that warns of weaker encryption.
I'd expect to see if on the AirPort as it's an older device - I'd have thought the Hub One would be AES though.
Mook
Seasoned Champion
Fixes: 9
@dvorak I can clear this message by selecting WPA2 Personal from the AirPort Wireless properties.
Fixes: 1,483
Nice Smiley
