Hub one on ADSL
Marksfish
Seasoned Pro
Fixes: 4
Hub one on ADSL
My Dad has a new laptop and when connecting it to my old BY Voyager router, a security message came up about an old, insecure wireless connection, to disconnect and find another. I connected anyway, but they want a new router now.
He is on a up to 8mb product with the Post Office, and pays £20pm for unlimited and any time calls, so doesn't want to change to a new provider as the cost is more. He just uses email and some basic browsing and banking.
Will the hub one work on a adsl connection or is it purely fttc, as mine is sat doing nothing while I use my own router?
13 REPLIES 13
Fixes: 393
Re: Hub one on ADSL
The Hub One will work on an ADSL connection BUT I'm not sure if it will allow the username/password for a Post Office connection? It's probably 'suck it and see'
Marksfish
Seasoned Pro
Fixes: 4
Re: Hub one on ADSL
I've seen elsewhere that adding a username for another provider should be possible, so now I know it is a adsl enabled router, I will take it over and try.
Fixes: 418
Re: Hub one on ADSL
@Marksfish
It's worth a go but make sure that you change the user name and password to the Post Office ones before trying to connect to the DSL line. The easiest way is not to plug the DSL cable in until you have set the router up and it's trying to connect.
Marksfish
Seasoned Pro
Fixes: 4
Re: Hub one on ADSL
I shall set it up at home before taking it to my Dad's place, hopefully it will plug in and play Smiley
Marksfish
Seasoned Pro
Fixes: 4
Re: Hub one on ADSL
To feedback finally, I can confirm the Hub One will not work on a post Office connection. There is obviously a hard coded range of isp's that the router will accept as a message of "this connection is not allowed" or similar sort of message is displayed when trying to input the PO username Sad  It's a shame as the router is now potentially landfill at the end of my contract. There should be an obligation on isp's (as there is on mobile phones) to be able to unlock equipment which is given to end users as part of a deal.
Fixes: 418
Re: Hub one on ADSL
@Marksfish
Are you saying that you cannot input the PO log in details even with the dsl cable disconnected?
Marksfish
Seasoned Pro
Fixes: 4
Re: Hub one on ADSL
Nope, only the power and network cables were connected to the router. My laptop was used to try to configure and rejected.
Fixes: 418
Re: Hub one on ADSL
@Marksfish
Well what about this as a Plan B?
Configure the Hub One as a Wireless Access Point. See. https://community.plus.net/t5/My-Router/Using-a-2nd-Plusnet-Hub1-as-a-Wireless-Access-point/td-p/138...   Turn off the insecure wireless on the existing router and using an Ethernet cable connect it to the Hub One, which can supply dual band WPA2 encryption.
Marksfish
Seasoned Pro
Fixes: 4
Re: Hub one on ADSL
Unfortunately they don't want an extra box, an all in one solution is wanted. Was just hoping this unused item could be used instead of buying one. Of course, they could re- contract and get a new one, but they are old timers and don't like change. Still on 8MB adsl with the fibre cabinet outside their door. Until the adsl is more expensive than their current connection, can't see it being changed as they don't use the internet very often and then, only really for email.
Fixes: 418
Re: Hub one on ADSL
Before spending money on a one box solution it might be prudent to make sure that it can used on a Post Office service.
One thing about using the Hub One as a WAP is that it can be switched off when they've not using the Internet. Maybe that would satisfy them?
Marksfish
Seasoned Pro
Fixes: 4
Re: Hub one on ADSL
I would have thought that any off the shelf, non isp branded router would be able to accept connection details, whether they all support adsl is another question. My Father's wife doesn't like one box, so 2 boxes is definitely ut of the question.
markhawkin
Fixes: 12
Re: Hub one on ADSL
@Marksfish
It seems that the Post Office broadband is a rebrand of TalkTalk internet.
You might find an old TalkTalk router that someone has to try.
Marksfish
Seasoned Pro
Fixes: 4
Re: Hub one on ADSL
I've had a BT Voyager 210  router working on the connection for years, but it is old and tired, so I know a "normal adsl router should work. Was just trying to re- purpose the one I had.
