Hub one often crashes/resets when I try to access advanced_settings->Home_network
- My Router
- Hub one often crashes/resets when I try to access ...
4 weeks ago - last edited 4 weeks ago
Hi all,
On the Hub One's menu, of late I've found that if I try to view the home network page under advanced settings, the router often (but not always) seems to crash. The network stops responding and the light on the box reverts to green and then may go through the flashing orange sequence for, say, 30-60s, before reverting the blue. The "connected time" also seems to suggest it crashed.
Firmware is 4.7.5.1.83.8.289
Has anyone else experienced this?
thanks
Simon
Re: Hub one often crashes/resets when I try to access advanced_settings->Home_network
Hi @Simon_F
Not experienced this issue myself but you might find the cause in the event log.
Troubleshooting >Event Log - In the drop down select System which hopefully gives a clue
Are you running a beta firmware version? if so I would alert @bobpullen
Hope this helps
Dan.
4 weeks ago
I did have a quick look at the log, but that was maybe 30 mins after the event and so a little hard to find. I might try to trigger it again early tomorrow before the everyone starts using the network and see if something does stand out.
RE the firmware: I think it was updated to .289 perhaps a week ago, as this is a "new" router and it came with what seemed like a relatively old version (.263). I don't know it that's a beta version though.
3 weeks ago - last edited 3 weeks ago
Managed to provoke it into crashing this morning at around 7:55~7:56. (I had successfully displayed the home nextwork graph, moved away to another page, and then tried to open the network page again)
There is nothing interesting in the system log:
10:10:39, 25 Jan. | STP Alert: Port eth0 leaving blocking state. |
16:58:19, 24 Jan. | (107972.690000) The system is going DOWN for reboot. |
Looking at a log of "all" is not much help either. It's noted a blocked access earlier in the morning, and then what I guess the restart after the crash.
07:55:58, 02 Feb. | ( 27.420000) WPA2 mode selected |
07:55:58, 02 Feb. | ( 27.420000) WPS enabled |
07:55:48, 02 Feb. | ( 17.940000) System start |
07:05:54, 02 Feb. | IN: BLOCK [16] Remote administration (TCP [47.152.139.117]:38630->[87.112.109.133]:22 on ppp0) |
I was half expecting to see a "malloc failed" or "segmentation fault" message.
3 weeks ago
Morning @Simon_F
It was worth checking the log, I would guess the device is unable to log an error as it's crashed!
Might be worth trying a factory reset, but you'd have to setup any port forward rules and static IP address is you have, I would not recommend restoring a backup.
Dan.
- My Router
