Hub one firmware update
David-26
Good morning everyone I’ve been with Plusnet just over a week and no problems with my router as far as I can tell. I noticed this morning that the router was showing a firmware update on 22/11/21 but I’m sure the firmware version hasnt changed from when I set it up initially I.e. version ending .263 There is nothing in the event log to show a recent reboot. Do I need to manually reboot or reset the router to apply any new version it may have downloaded or should I just leave well alone? Thanks in advance for any help or advice.
4 REPLIES 4
Fixes: 392
Re: Hub one firmware update
@David-26 A one-off reboot should fix it.
David-26
Thanks for the fast reply John. My wife is working from home and in and out of teams meetings so I’ll do a reboot this evening when things are less busy and I won’t get any grief 😄
best regards
David
Fixes: 392
Sounds like a plan 👍
David-26
Hello John
router rebooted as suggested, home page now showing version 289.1.3 and all connected devices working perfectly.
Thanks again
David
