Hub one firmware update request
I have repurposed a spare plusnet hub one to replace a hub zero on ADSL for a friend who is a a current plusnet customer.
The connection seems to drop at least once a day on the hub 1 whereas the hub zero would maintain a connection for 2weeks.
The firmware on the hub 1 Is quite old
 Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2
It won't update automatically as it seems to be on the cease list.
I am happy to pm the account details over to a staff member
You can check out but you can never leave ( easily)
11 REPLIES 11
Fixes: 59
Re: Hub one firmware update request
Hi @Protech
Can you please PM us the following so we can add the router to the account:
- The username of the account
- The serial number of the router
- The MAC address on the router (only first 6 characters are needed)
Once we have added this, a factory reset should push the update.
Thanks.
 Lauren Barry
Hi @LaurenB
PM sent
Fixes: 391
Thanks for the PM @Protech
We've added the details now
As @LaurenB advised above if they carry out a factory reset it should register on our end and the new firmware pushed out within 24 to 48 hours.
If it still hasn't updated after then let us know and we can see if we can get that pushed out remotely
 Matthew Wheeler
Thanks @MatthewWheeler
I have done the reset twice and waited 48hrs , however the router still appears to be on the ceased list
Regards Martin
22:09:20, 08 Dec. (34761.640000) CWMP: session closed due to error: Could not resolve host
22:09:20, 08 Dec. (34761.590000) CWMP: Server URL: https://ceased.tr69.p; Connecting as user: ACS username
22:09:20, 08 Dec.
(34761.580000) CWMP: Session start now. Event code(s): '6 CONNECTION REQUEST,0 BOOTSTRAP,4 VALUE CHANGE'
Fixes: 43
Hi @Protech,
I have looked into it and I can see that my colleague added a 'colon' into the serial number by mistake which is why it hasn't worked. I have corrected this now.
Please factory reset the router again and it should update within the next 48 hours.
Thank you for your patience.
 Faris
@Beyhive
Firmware updates now being recieved
Tags (1)
Fixes: 43
You're welcome @Protech,
Let us know if there is anything else we can help with please.
 Faris
Our firmware is Software version 4.7.5.1.83.8.263 | Last updated 26/03/19. Is this the most recent?
Trend Micro Housecall says this router needs a firmware update as 2 vulnerabilities:
SSL-Poodle Vulnerability
SSLv2-Drown Vulnerability
1 risky post open SMB 445/TCP
Hi
Could you please advice me on how to go about getting a firmware update on my hub one
My household experiences constant WiFi problems
I'm currently on 4.7.5.1.83.8.226 last updated 17/09/16
Seasoned Champion
Fixes: 24
@laura033 Unfortunately the latest official firmware release also has problems with WiFi, there is a long thread about it in this forum, it has been going on for over a year and is not fixed. Some customers have had test firmware downloaded to them but no final fix has been found yet.
Fixes: 931
Thanks for getting in touch @laura033
If you've got firmware that old your router's dropped off our hardware management system for one reason or another. Can you send me a PM with your router's serial number and MAC from the label on the bottom of the router?
I'll then get this re-added and after you carry out a factory reset you'll be running on the latest.
