Hub one continuosly flashing orange and no internet
- My Router
- Hub one continuosly flashing orange and no interne...
08-01-2017 12:15 PM
Can someone help, recently the hub has been dropping connectivity only to reboot itself, which resolves the issue for a time, before doing it again.
However yesterday it now has a continuous orange light and no internet connectivity.
I have gone through all the checks stated on the PN website, checking cables, reset etc and even plugged it into the test socket on the master wall mount and still the same issue!!!!
After looking on here is may appear that the hub is faulty ? Has this happened to anyone recently ?. This is the second time in the space of 2months I've had issues with no broadband ( the first was on ADSL ) so I upgraded to fibre . And now I'm having the same problems. im not best pleased to have issues again and i am getting fed up with paying for a services or equipment that I'm not getting. I have an open question on the members centre , but that will be another 2/3 days before they reply and in the mean time I have nothing g to show for a service I'm paying for.
Does anyone have any suggestions ?
Message 1 of 4
(2,190 Views)
3 REPLIES 3
Re: Hub one continuosly flashing orange and no internet
09-01-2017 10:57 AM
Have you raised as a fault so it gets progressed. ?
Unsure about reference to members centre, as the Ticketing system was done away with some time ago unfortunately
Message 2 of 4
(2,143 Views)
09-01-2017 11:38 AM
Yes, it has been reported as a fault. The question was also raised in the members centre ... Received a call 19 mins ago and they state BT cannot find an issue with the line ,although checks by plusnet showed fault with phone line !!! So an Engineer is due tomorrow morning to hopefully resolve.
Message 3 of 4
(2,134 Views)
24-01-2017 2:11 PM
OK and how is your service now, did they manage to fix the fault for you?
Message 4 of 4
(2,077 Views)
- My Router
