Hub one USB port specs
hml57
Where in http://192.168.1.254 do I find out the hardware model of my plusnet router?
I am interested in finding the specs of the usb port. 2.0? 3.0?   my 4 Gbit/s ethernet ports are busy and I have a 5th box that I wanna link up with a usb cable.
What cable I need? What latency to expect? USB vs ethernet 1 Gbits/s ?
1 REPLY 1
Fixes: 391
Re: Hub one USB port specs
@hml57
It’s a very basic USB1 output that uses the obsolete SMB1 protocol. You can plug in a memory stick if you don’t mind downgrading your security to SMB1.
If you want more Ethernet ports you can buy a four port switch for less than a tenner
