Hub one USB port specs
- My Router
- Re: Hub one USB port specs
09-06-2021 8:46 PM
Where in http://192.168.1.254 do I find out the hardware model of my plusnet router?
I am interested in finding the specs of the usb port. 2.0? 3.0? my 4 Gbit/s ethernet ports are busy and I have a 5th box that I wanna link up with a usb cable.
What cable I need? What latency to expect? USB vs ethernet 1 Gbits/s ?
09-06-2021 9:31 PM
It’s a very basic USB1 output that uses the obsolete SMB1 protocol. You can plug in a memory stick if you don’t mind downgrading your security to SMB1.
If you want more Ethernet ports you can buy a four port switch for less than a tenner
