Hub has a strange fault, any chance of getting a replacement?
- My Router
- Hub has a strange fault, any chance of getting a r...
27-04-2021 5:04 PM
Came back to Plusnet a few months back. At first all seemed fine. Then I noticed I was getting kicked off the WiFi sometimes. Then the family started to complain. It seem roughly once a day one device gets kicked off happening to PC, phone, tablet and games system. sometimes a re-start worked, sometimes had to forget the network and re-join.
I have an old NetGear, so plugged that in and everything is fine again.
Any Chance PlusNet will admit there is a problem? I'll grant you it's not a run of the mill issue!
Cheers
Re: Hub has a strange fault, any chance of getting a replacement?
27-04-2021 5:11 PM
Moderators Note
This topic has been moved from ADSL Broadband to My Router
27-04-2021 5:52 PM
- My Router
