Hub blue light far too bright...
Anthony15
Would be nice in the future to see if they could turn hub blue light lower down as I've changed from bright high to low but sill too bright to cross the room. I had to cover up the bright dimmer. I hope you stored this setting better condition in the future... Thanks A.
5 REPLIES 5
Browni
Aspiring Hero
Fixes: 59
Re: Hub blue light far too bright...
Couple of suggestions here.
AlaricAdair
Champion
Paint said lights with your red nail varnish. Cheesy
Now Zen, but a +Net residue.
I use Blutack.
A small blob, just enough to cover the LED, and cupped so that it has a small opening at the top, so LED cannot be seen from the front, but can be seen from above.
A bit like this...
I do this with all my Electronics, especially PVR's in the Living Room & Bedrooms...
jaread83
Fixes: 81
This is what I do as well @Anonymous. Blutak is wonderful stuff. The blinking blue light on the front of my PC case was quite distracting when we had the base unit in the lounge to use for watching films and TV so a blob of blutak sorted it out as the light couldn't get through it.
I save the Intel Inside stickers from the processors I’ve bought and use these as they are thin enough to diffuse the light but you still know when its on, and people think your gadget runs on an i7. Cheesy
