Hub Zero router
- My Router
- Re: Hub Zero router
Hub Zero router
07-10-2020 4:56 PM
I'm trying to work out how to access the logs on my 2704n router. Can anyone help?
Re: Hub Zero router
23-10-2020 8:17 PM
Bit of a delayed response, but why are you looking for them?
If there's nothing available at http://192.168.1.254/expert_user.html then you're probably out of luck.
Re: Hub Zero router
23-10-2020 11:40 PM
I want to check to see what sites have been visited from my home.
Re: Hub Zero router
24-10-2020 12:47 PM
That is not recorded in the log. This is limited to events related to the hub operation, not sites visited.
Re: Hub Zero router
24-10-2020 12:59 PM
Ok, thank you
