Hub Zero router
Hub Zero router
I'm trying to work out how to access the logs on my 2704n router. Can anyone help?
4 REPLIES 4
Fixes: 158
Re: Hub Zero router
Bit of a delayed response, but why are you looking for them?
If there's nothing available at http://192.168.1.254/expert_user.html then you're probably out of luck.
Re: Hub Zero router
I want to check to see what sites have been visited from my home.
Fixes: 165
Re: Hub Zero router
@Thomas43
That is not recorded in the log. This is limited to events  related to the hub operation, not sites visited.
Re: Hub Zero router
Ok, thank you
