Hub Two
kg11
Hub Two
I received/bought my Hub Two a year ago when I renewed my contract but have never plugged it in and am still using Hub One.  Is it straight forward to swap them out even after such a long time or do I need to try and actually speak to Plusnet first?
6 REPLIES 6
Fixes: 392
Re: Hub Two
@kg11 Plug it in. It may not update to the current firmware ( 0.10.00.04201-PN ) after being 'dead for so long, though. If it doesn't come back and say so - there are ways to sort it.
Fixes: 586
Re: Hub Two
@kg11 @jab1 it MAY also not autoconfigure, since its possibly dropped off the management platform.
Check that the broadband username is showing correctly and not [email protected]. If its stuck on the setup one, then you'll need to disconnect and change the username/password to the correct account ones.
Fixes: 392
Re: Hub Two
Good point, @MisterW - in which case, it would need referring to Bob Pullen in an attempt to get it back on the platform?
Fixes: 586
Re: Hub Two
I think the Help team can also help re-attach them to the management platform
kg11
Re: Hub Two
Thanks all.  I just need to set aside enough time to try plugging in and allow time to sort straight away.  May not be for a few days as life is rather complicated at the moment.  I always have trouble trying to get through to PlusNet support and now can't find the phone number for them for when I'm ready to try?
Fixes: 392
Re: Hub Two
If you need it, it is 0800 432 0200, but you will probably get better help through these forums.
