Hub Two Event log times are changing?
Madeleyite
Fixes: 7
Re: Hub Two Event log times are changing?
Wouldn't you think that when events get recorded the timings would be set-in-stone except for the new events that get added? When new events get added the PN firmware must be re-creating the whole log with different timings instead of just adding the new events.
This is crazy. If I edit a Word document and save it I am only saving the changes. The rest of the document remains unchanged.
Come on PN. Get your act together.
RealAleMadrid
Fixes: 68
@Madeleyite  Not sure why you are so bothered by this slight discrepancy in the log timing values, is it really that important?
Your connection issues and line drops are much more in need of a fix.
I can confidently predict that Plusnet will not make any effort to update the hub firmware to sort out the timing bug.
Fixes: 389
Agree totally with the first line
And I suspect, but may be wrong, that the time issue is due to the time server(s) and nothing to do with the Hub  - firmware or anything else.
bobpullen
Fixes: 331
@Dan_the_Van wrote:
Regarding the event log timings, I check mine earlier and I have a 2 second drift over 24 hours 🙄
I'll have to find some time to look into the feasibility, but I may be able to force the hub to use a time server other than Plusnet's. If I can find a way to do it then that would at least help elimintate the NTP server as a contibutor. Happy to take it from there.
