Hub Problems
iruhaku101
Hub Problems
hey,
having a problem with the hub with throughput. seems to limit me to 25mbps. I've been trying to diagnose it and the only thing i can think of is that an iphone is connecting at say 6mbps (was in the dhcp logs) then its bringing my whole network to a halt. then it doesnt seem to return to normal (even though the iphone in question has left the network). my laptop is syncing at 433 mbps but 25mbps throughput???? if  i reset the router things return to normal until a low sync then it happens again. obviously i cant keep resetting the router or DLM may get involved. any advice or tips would be great
2 REPLIES 2
bill888
Aspiring Champion
Fixes: 33
Re: Hub Problems
Perhaps same issue as reported by another user?
https://community.plus.net/t5/My-Router/Hub-one-wifi-5Ghz-speed/td-p/1492377
(5 GHz wireless SSID also renamed with no apparent improvement)
iruhaku101
Re: Hub Problems
yeah, I've decided to give up on this hub and buy a vr600 or 900.
