Hub Problems
- My Router
- Re: Hub Problems
Hub Problems
05-12-2017 6:49 PM
hey,
having a problem with the hub with throughput. seems to limit me to 25mbps. I've been trying to diagnose it and the only thing i can think of is that an iphone is connecting at say 6mbps (was in the dhcp logs) then its bringing my whole network to a halt. then it doesnt seem to return to normal (even though the iphone in question has left the network). my laptop is syncing at 433 mbps but 25mbps throughput???? if i reset the router things return to normal until a low sync then it happens again. obviously i cant keep resetting the router or DLM may get involved. any advice or tips would be great
Re: Hub Problems
06-12-2017 10:38 AM - edited 06-12-2017 10:41 AM
Perhaps same issue as reported by another user?
https://community.plus.net/t5/My-Router/Hub-one-wifi-5Ghz-speed/td-p/1492377
(5 GHz wireless SSID also renamed with no apparent improvement)
Re: Hub Problems
06-12-2017 6:44 PM
yeah, I've decided to give up on this hub and buy a vr600 or 900.
