Hub One
- My Router
- Hub One
Hub One
02-07-2020 11:37 AM
Hi I'm a long time Plusnet customer and my contract runs out this month, I'm happy with the service but not with the Hub One router, not sure what it is with the house but I've never been able to get full wifi thoughout, it's not a large house and neighbours in similar properties can get coverage with other providers routers, I installed an extender which is hit&miss,
I'm hoping Plusnet have a new type router they can offer otherwise I think I will change provider, does anyone know if a new router is available please?
Re: Hub One
02-07-2020 1:32 PM
HubOne is as good as it gets from Plusnet.
Better routers aren't expensive though.
Re: Hub One
09-07-2020 2:16 PM
Thanks for your reply Owain, decided to get a BT hub as you suggest, renewed contract and upgraded to fibre plus, that was a week ago, just discovered there is a problem with the order? sadly no one has bothered to contact me.
